High or low pressure oil sender switch?
(In Topic #215959)
Trying to confirm which oil pressure sender switch this is in the photo...
It's at the end of the blue wire (and needs replacing).
Thanks!
The switches are colour coded, white 1.8bar and brown 0.3bar and prob also have rating stamped on them if you remove them and have a look see.
Thanks. Mine is white, so will order that one (thought they might be colour coded, but wasn't 100%).
High pressure sensor near the oil filter as that is where the oil pressure is high as oil is pumped through the filter and low oil pressure at the side of the head as the oil pressure is a lot lower up there.
I was told to put them both on the oil filter with a tee piece.
1983 MK1 Golf four door 1.8T 20V BAM remapped, MK2 dash and loom, TMI interior. daily.
2014 VW California 5.1 with full Sportline kit, weekend home.
Pete thats because you have a 20v
for an 8v what you have there is correct, big white switch 1.8 bar at the back, smaller white switch 150 degree oil temp sender for MFA on the left
