Front fog lamps not working - Mk1 GTI Campaign
(In Topic #223742)
As the title suggests - my front fog lamps on my 83 Campaign are not working. Here are details/checks so far.
1. I have fitted a new switch - as I had one lying around - VW original.
2. Rear fogs work fine.
3. Light in the switch only comes on when rears are on - which is how it has always been.
4. No power getting to the front fogs.
5. All other lights working OK.
Done a fair bit of searching - and given the above - reckon it's an issue with relay OR fuse. I have Haynes manual but that makes no mention of fog lights and can't find any wiring diagrams - do these have a fuse/relay associated with them. If so - number/location?
Cheers!
These are fog lights - not spot lights. They are the standard Campaign middle lights that would come on when the you pressed the fog light switch to the 1st position.
Check fuse 6
Last edit: by Steve1973
I just purchased a plug and play quad light loom which have relays, fuses as part of kit, you just hook it to battery and the headlight terminal. You can tuck the harness away with tie wraps, you can't really see them.
No doubt the lights looks brighter, it is a safer set up and does not cause load on the headlight switch which are known to burn out.
Try this
https://www.heritagepartscentre.com/uk/WC941W000-headlight-wiring-loom-harness-upgrade-kit.html?gclid=CjwKCAjwkPX0BRBKEiwA7THxiNwYxxVbW4JO3pmnc97nId4_VB1vI1sWN6QJZcD62-qqIMiknWkWlRoC_hEQAvD_BwE
BRINZ said
I had similar issue with my spots…… probably a break in cable somewhe6.
Try this
Hello Brinz, the Loom you are referring to, how do you hook it up with the cabin light switch?
thanks
Replacement fusebox, new harness connector and its all ok now.
Follow the harness. Also make sure earths are good.
I did have some info in some manuals somewhere which helped me…. DM if you need any help - might be able to dig up something for you..
Hope that helps…
Ocean Blue '76 Golf LS - Sold
Black Campaign GTI
Silver Campaign GTI
Black Campaign GTI
Silver Campaign GTI
