Finding it difficult to get it into 5th gear!
(In Topic #207693)
How can I sort this?
If you are having problems with just 5th I would guess the linkage needs adjustment, has the problem just started to happen?
I just replace the bushes with this kit.
http://www.ebay.co.uk/itm/SCIROCCO-GOLF-MK1-GTI-GEAR-LINKAGE-BUSH-KIT-C163-/200267258146?fits=Model%3AGolf&hash=item2ea0dbd922:m:mkKGQI2tTDvISm0Y7UToHNg
There is a guide this site about setting up the linkage and replacing the bushes.
You can get kits with all the linkage bushes and rods, you will need to inspect the rods for wear etc but my rods are still OK after 27 years and 270,000 miles so I have not changed them, a blob of grease on the balls which the rods fixes to helps with reducing wear, done the bushes about 4 times!
I had a little problem finding 5th gear when I changed from a 4 speed box the a 5 speed and I found a little adjustment on the plate which the gearstick is fixed to the floor helped, there is a couple of bolts fixing it to the floor I loosened them and moved the plate a mm to the left I think… And that helped.
It was a little trial and error but after a couple of goes it helped.
If you can from underneath the car remove the plastic disc from below the gearstick rubber boot and measure the gap between the bottom of the gearstick arm and the metal stop there meant to be a set measurement but can remember it…
Step 1 shows the plate with the 2 bolts I'm talking about.
Step 47 shows the gap at 19mm between the bottom of the gearstick and metal stop plate, this is plate the gearstick hits and you have to push it down to engage reverse, stops you getting reverse instead of 1st!
You can replace everything if you wish but I've only ever done the bushes in the engine bay.
If it was me I would check the adjustment and have a little play with the plate on the gearstick then if not any better then start replacing things.
I always go for the cheapest easiest option 1 st then move on there there.. Edit.. Forgot to post the link…View topic: .GUIDE : Refurbishing your gear linkage - The Mk1 Golf Owners Club
There is a guide on the how to section about seat covers so may be helpful for your other thread about rattly seats?
http://www.ebay.co.uk/itm/COMPREHENSIVE-GEAR-SHIFT-REPAIR-KIT-5-SPD-VW-GOLF-MK1-CAB-SCIROCCO-JETTA-/351829916771?fits=Model%3AGolf&hash=item51eab27c63:g:XFcAAOSwFdtXy-zk
Now my gear change is spot on and the gear stick has virtually no movement when in gear. The bushes with the most play on mine were the ones on the end of the gear stick!
Just to help things a little more I also changed the gearbox oil and that made a huge difference! I would suggest doing that anyway unless you know for certain it has been changed recently.
Often over looked and never replaced. Alot of manufacturers now recommend 40,000 miles for an oil change but I think 60,000 miles is often enough for me.
Since switching to fully synthetic oil I've lost the 2nd gear crunch when the gearbox is cold and gear changes alot smoother. :-)
Last edit: by mark1gls
2 bottles is plenty as you will never be able to drain every last bit of oil out of the gearbox.
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1989/p/car-accessories/engine-oils-and-car-fluids/car-tranmission-oils/manual-transmission-fluids/?522776022&0&cc5_868
£12.87 with the discount.
mine did this and symptoms were the same, right down to having to press the stick down to get the extra reach needed to get 5th lol
Steve_Matthews said
Check the gear shift alignment is correctly set.
