Clutch grating noise 91 clipper
Hi guys,
I have a grating noise coming from the clutch when pressed. When idle there is no noise….when fully dipped there is no noise. It's kind of just at the initial portion of the press. I have ordered some gear oil and plan on checking and replacing the oil when it arrives
With the engine idle it's fine. If I raise the arm of the clutch in the engine bay the noise appears
It's a 91 1.8 engine
Bruiser23
Sounds like it might be the idler bearing. When was the clutch last replaced? Any ideas?
Ian
(PS I've moved your post)
Cornish Host.
1980 VW Derby
Clive the Cabby
Ujum the Invisible
Mynx the  Tintop
thanks for moving the post…
according to the reciepts from the previous owner, it looks like it has had a new clutch kit and a new clucth release bearing in 2015
IMG_8230.MOV
This video shows slowly dipping and then releasing the clutch. The noise only happens  during dipping and releasing of the clutch
Last edit: by Bruiser23
hmmmmm
Can't see the video.
Perhaps upload to you tube and link it?
Ian
Cornish Host.
1980 VW Derby
Clive the Cabby
Ujum the Invisible
Mynx the  Tintop
Mk1 clutch noise - YouTube
Ok, uploaded to YouTube so hopefully it works. Cheers
Makes the same noise as mine did when I changed the clutch but didn't bother with the release bearing.
Unless anyone else has an idea, that's what I'd suggest.
Ian
Cornish Host.
1980 VW Derby
Clive the Cabby
Ujum the Invisible
Mynx the  Tintop
