Can someone please identify this cable for me?
(In Topic #235400)
Thick Pink cable rear of engine
Finally found some time to start working on Cabrio, today I fitted, with relative ease and a few good pointers from my step dad on timing marks etc… a new distributor, lead, plugs, coil and ICM. Fired up perfectly first time, just needed a small tweak of the distributor once running. However when the new coil was fitted I noticed a cable near to the coil which connected through with a white connector that appears to be defective/melted? one side of the connector is a thicker gauge pink cable the other a thicker gauge red/white, I managed to strip the cable insulation back chop out the damaged section and re-terminate. Nothing seems effected with the car so I assume the termination has done the job. Could someone please give me a heads up what this cable does/is for and what could have caused the original damage?
Thanks guys!
