Cabriolet Aerial?
(In Topic #227100)
Thanks, Alwyn.
I too thought about keeping the rubber type but since not OEM looking i binned it.
Electric Telescopic Aerials
On the drive
Myvalver 89 GTi Grey mk2 16v
If your Radio has the 90 bend then your antenna (new) may need the 90 bend which are a beatch to run or the 90 degree angle connection.
To feed the new if Straight connector, I usually cut the old feed wire at the antenna, then I strip the internal coax back about 2 inches and using the old outer case I place that over the new connector and with a single wrap of electrical tape tape it back together as tight as you can and then up the new cable about 2 inches.
As this allows me to pull the new cable in to the cabin using the old cable behind the radio. Use lots of Lube so you don't pull the Grommet it to the car… You can also remove the grommet from the outside and pull it up the spliced part to make it a tad easier…
Second way is to run a feed string or wire by attacking it to the old antenna wire and pulling it through the cabin to the new radio, (it has to be about 3 feet long) and allows you to tape it to the new easier and for a longer about 3 inches up the new antenna cable.
Once you have it all pulled up to the radio be dang sure that you do the following.
1. replace the feed through grommet on the new cable
2. make sure that you have a drip loop stop on the new cable to prevent water migration in to your cabin. I also usually use RTV (silicone) to seal the grommet to the cable and to the frame to make sure there is no water migration.
It took me about a few searches on the interweb and local car parts places to locate the antenna that I liked the most…
Drip stop loop.
Manual ones are lovely and simple and cheap too, I just don't like the idea of having to extend the aerial every time I want to listen to the radio; will it pick up any signal when still down? Also I worry that strong winds could snap some of the taller ones, does anyone have any experience with this?
I'll check out that link now Kenneth, thank you.
Cheers, Alwyn.
I have a solid whip on mine.
