Brake bleeding
(In Topic #211237)
Can anyone help? Having trouble with bleeding the brakes
I use it regularly… there are plenty of how to's to build one on the youtube and google search.
I used a 4 dollar 2 quart pump sprayer you only need about 14psi so you don't want to over pump.
Fill with Brake fluid and add a Brake Cylinder res cap (the later cabriolets have the plinger bits so it is easy to drill a hole.). I used a brass barbed fitting and nutted it to the cap.
My Other Special tool is a Might-vac, the only thing I add is a 1 quart collection jar on the suction side.
Take a Metal Capped quart Pasta Sauce glass jar. Classico, ragu….
Find some vinyl tube about 5 feet the diameter of your bleeder ports, as well as the diameter of the mighty-vac.
Cut one about 3 foot, and one about 2 foot.
Insert the shorter length into a hole that you drill or punch in the cap the hole should be slightly smaller than the vinyl tube, and let it extend into the jar about 1 inch.
Take the longer hose and force it almost to the bottom about 1/4 inch…
You will mix up JB-Weld and force it in and around the jar on the top. I then attach the mighty-vac to one side and plug the other, and draw about 2 lbs of merc….This places the jar under vacuum and draws the jb-weld in to any crevice. Then release pressure and in 10 minutes you can place some on the bottom side just don't get near the seal area….
Bleed the rears first then the front.
Once you use a mighty-vac or power bleeder it is to hard to go back the the two person pump 3 times and hold…that I used for years and years and years.
OBTW this is the 3rd bleeder that I have made in 15 years…. 1 I drove over, and one stopped working, so I just made another…
Using a power bleeder makes it very easy to change to Synthetic fluid, and since all your parts are new it would be a good time to think about changing….The newer synth is less Hydroscopic.
