Bonnet Lifters Bracket...
(In Topic #219766)
Ive done this on my T5 and it was easy as you just swapped out bolts - surely this could be the same with the right kit?
Any help apreciated, thanks
Measure the required gap and find an OEM strutt of the same length when at its shortest with the same size thread as the bonnet, nut and bolt the other end through the existing wing hole
Aftermarket lifters look cheap and corrode quickly
Current rides:
However
Some mods are needed. You will need to cut down the bonnet lifter and re thread the end, iirc it was about 15mm that needed to come off. The hole in the wing will also need to be drilled out a bit too.
Do a search on the Forum as I asked the qu2some time back and got a decent answer
Ian
