Blowing Downpipes
(In Topic #234435)
Hello,
I'm hoping someone can help. Bought an OEM downpipe, had it fitted and it was blowing from the manifold to downpipe seal. So, bought another manufacturer's downpipe, fitted and same problem.
Has anyone any idea why this would be? I have a 1.6 carb cabriolet with the c clips on the manifold to downpipe.
Many thanks in advance for any advice.
Rachel
Rachel
Was a new gasket fitted? Also the existing clips might have become stretched?
https://www.heritagepartscentre.com/uk/161298115-exhaust-down-pipe-gasket.html
Thanks but yes both gasket and c clips were /are new too.
Are you sure the manifold isn't cracked, been a long time since I had one of these manifolds but I seem to remember changing one because of cracks when I was a youngster!
Is the gasket the correct size and a tight fit on the manifold?
Make sure your pipe hangers are good, and that your pipe is aligned, Engine and tranny mounts can cause this type of issue.
I have never seen a toilet bowel exhaust manifold crack, as they are beefier than the ones on the 90's cabriolets as I have had 3 that were more cracked than a politician.
Thanks both, I'l get all this checked - 'more cracked than a politician'
