84 gti K Jet
Not running properly
They both use a 10V stabilizer on the rear of the cluster (clocks).
This would indicate to me that you have 1 of the 3 following issues.
Bad power to it.
Bad Ground to it.
or it is plain bad as there isn't 10V.
In the archive section How-to's there is a List of DIY's by briano I think it may include digifant . but in the 4 or 5th post there is a list of electrical DIY's (clink the Link in my Signature) and one is testing the gauges with a battery.
Guide here to making a tool to remove the flanges, I found the hardest bit is getting the new C clip back on, it either goes on 1st time or you are fighting it as it pings off across the garage…
020 Flange
pictures etc of my home made tool and access. You will need to drain the oil from the gearbox so good time to change to fully synthetic gearbox oil, info in link…
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=technical%2Frunning-gear_2%2Fgear-box-crunch
Regional Host NE
alternatively if you get yourself a tight with an advance wheel you can use the tdc marker on the crank pulley
Welcome to BrokeVW.com
with the brake master the bungs should be fitted dry, if correctly made they are tapered at the base and this is what seals them to the hole in the master cylinder same as a bleed nipple or brake line. remove the bung and make sure theres nothing in the hole or any buurs on the bung which might be causing an issue. you could fit a bleed nipple in the hole instead and see if that stops the leak.
Check your wire on the large white sender on the oil filter flange….
Then check your oil, and change it and the filter.
