84 gti K Jet
Not running properly
next disconnect both oil switch wires and see what happens, you should have no light ignition/idle but the ligt+buzzer should flash when revved to around 2k rpm.
If you earth the yellow switch wire the light should then come on with ignition, if you earth the blue/black wire at the filter housing then the light+buzzer shouldnt sound when revved
look at the brown wire to the cluster, this should be earthed. it runs over to a male spade near the fusebox on cars with mfa cluster then theres a brown/white wire plugged into it in the engine loom which earths to the head.
it could just be the oil warning board has gone faulty, it does happen. its the L shaped one clipped inside the speedometer unit so can be replaced on its own. of for the short term can remove and leave it out to shut up the buzzer while you source a replacement. doesnt have to be from a GTI set either just needs to be from similar era of mk1, cab and polo 321919064K
How to disable the oil buzzer alarm on 86-91 Vanagon - YouTube
pre-90 mk2 are the same units as fitted to the scirocco and still have the oil warning board, but the part changed around 1985, not sure if the later part is compatible
