1992 Cabby. Timing.
Morning all.
I have a 1992 1.8 Clipper Cab (well was a 1.8, now a bored out, fast road, 1.9) but still running all the exact same ignition parts etc. With the addition of a 4-1 manifold and weber dmtl 42/34 carb.
It has all been set up and it's now legally on the road and drives mint. However, the engine is pinking when under load and up to temperature. Is it literally a case of turning the dizzy to retard the timing a little bit to stop this?? Which way do I turn the dizzy if so?
Cheers!!!!
Chiz
1992 Clipper Cab converted to single headlights
Powered by 1.9 TSR Donnington gasflowed engine
4-1 manifold
Stainless steel custom exhaust system.
Now rocking a fresh new mohair roof and respray 🤙🏼
Yes mark where the dissy is now so you can see how much you have turned it and if it all goes wrong you can turn it back, there is a little cut out on the engine block you can use or I scratch a line from the end of the dissy clamp,  loosen the dissy clamp a little and twist the dissy anti clock wise to retard it a little. See/hear how it drives as it might need a little more adjustment.
