020 Gearbox - where did these come from?
(In Topic #235952)
Ball bearings inside thrust bearing housing
You won't know anything wrong with the bearing as it's only engaged when you press the clutch pedal down.
More info on the bearing.
TO Bearing
Remove what’s left of the old bearing and fit new one.
https://www.ebay.co.uk/itm/221185983385?fits=Car+Make%3AVW&hash=item337fb64399:g:jCUAAOSwSzRZQ4JL
Thanks for the info. Do I not need to find out where the missing 4 ball bearings have gone from the throw out bearing before I fit a new one? Where are they likely to be?
mark1gls said
With luck the remaining bearings will be in the bearing case?
Sadly not, I have 4 missing balls.
Is there still oil in the gearbox? If so you could get it level so that the drain plug is at the lowest point, similar to how it would sit in the car and drain it, see what comes out. Not sure if you can flush a gearbox. You can get magnetic drain plugs, could stick one of those on, put a bit of thinner oil in and swish it about and see if that moves them to the magnet.
Will have to sieve the oil in the catch can to see if any drained out already, and then try to do as you suggest. I've removed the remainder of the throw-out bearing and I'm missing 3 of the 7 ball bearings. I really don't want to start opening up the gearbox if I can help it.
Last edit: by Pistol
i just checked it myself and i now see there is one big hole next to 5th gear so maybe want to make sure you dont angle the greabox where the balls could roll through that hole but you might get lucky and just find them all in the fifth housing. if not, they will be in the main box and you are going to have to play go fish or remove the main housing.
Last edit: by Shubbs
