Car covers
(In Topic #147760)
Car covers
My garage isn't going to be ready for a few weeks and am just looking for an interim measure.
I've read some negative things about car covers and them damaging paint work etc, all comments welcome….
I don't really just want to stick it on the drive due to birds dropping all over it etc etc..
Currently Mk1less!
Currently Mk1less!
The paint blistered sligthly and still got scratched.
I have just ordered some pattern paper off ebay and am going to make a half cover to the top, down the widow level at the scraper seals, to the edge of the boot and to the bottom of the windscreen.
I have heard you can wrap fleece over the car to protect the paint? Not many birds about in winter they tend to migrate etc.
It does lead to the question is a half cover or full better? Anything that will move in the wind will rub where it touches, plus if the fleece gets damp will this hold the moisture against the Paint.
So covered or uncovered…????
Currently Mk1less!
Currently Mk1less!
Stormforce covers are good
I haven't decided yet as to what material to use as yet.
Wouldnt want it rubbing on the paint.
Problem can be solved by buying a cover for a slightly bigger car.
I am not bothering with a full cover this winter. Reading through here shows as pointed out more negs for a cover than for. Unless you got loads of money for a carcoon air chamber or permabag.
A good wash, polish and wax up half cover should do.
What you putting on yours Ceri or have you a garage now?
When I have used it outdoors it does strap down well with two buckles to go under the belly of the car, however it does as bignorm says only cover half the wheels.
Big norm just sent you a pm.
So you take ages re polishing the swirls out.
I also have the cheaper halfords one, which I use when I'm at work as my car leaks.
Im not fussed about it only covering half the wheel.
Afterall they are designed to protect the paintwork.
At the moment mine is in a garage, but once outside ill be buying a stormforce cover.
Once the straps are attatched the cover wont budge.
Depends how anal you are about your paintwork.
Currently Mk1less!
Currently Mk1less!
If you're after an outdoor cover I would always recommend that you invest in a waterproof and breathable cover. Some covers are water resistant, which is kinda meaningless. They'll resist some water and let the rest through, may as well not cover your car really. Breatheability is essential too. Moisture will gather on the surface of your car even when covered due to condensation. If the cover isn't breatheable the moisture will remain trapped under the cover and start to cause mould and in extreme cases, rot.
Also make sure it's a tailored cover. A semi fit or one size fits all cover is going to move about in a breeze and this movement will cause abrasion against your paintwork.
With any cover it's essential to make sure the car is properly cleaned (2 bucket method) prior to covering or any grit on the paint when it's covered may cause abrasion.
If you want all these features then you're going to have to pay for them. If you're not that bothered and just want to cover the car, then then you can get a cover from Halfords for about 50 quid.
