89 CABRIO GTI, FUEL/STARTING PROBS
whats the result now matey
tried the warm up regulator yet?
rebuild in progress....
Work still planned:
change rear bushes to polybushes, fit new rear shocks, renovate suspension/brake components(rear) and fuel tank.
professional respray
professional leather re trim
new 15 inch alloys/tyres.
Most of this probably over the winter…..
IT WILL START, BUT RUNS ROUGH/NOISY, AND IS DIFFICULT TO DRIVE, ESPECIALLY WHEN IT WARMS UP, AND IS UP AND DOWN WITH THE IDLE AND KEEPS STALLING. THERE IS NO POWER WHEN I TRY AND ACCELERATE, JUST A SLOW BUILD UP IN SPEED, AND A LOT OF VIBRATION…………….
ANYBODY KNOW ANY 'REAL' WHIZZ TUNER/MECHANICS WHO WILL BE ABLE TO HELP GET THIS OLD LADY SINGING AGAIN…?, YORKSHIRE AREA.
THANKS
MARKYMARK
I looked at buying a fuel pressure gauge but they are very pricey, so I 'took a guess' at the fuel pump, which was the faulty part but the root cause was that the fuel tank was full of rusty/flaking metal, due to the car being worked on and the fuel stored in an old, metal, rusty, fuel can.
Is the fuel pump noisy or quiet?
I have already replaced the fuel pump with a new Bosch item, with only noticeable sound being the priming for a couple of seconds when you switch on the ignition.
The car will start reasonably easily, and after a very rough twenty seconds or so will settle into a not too bad idle, at about the right speed, and the car will rev quite freely, and sounds quite sweet.
When the car gets warm the revs drop and the car nearly stalls then the revs start searching/dropping etc..and occasionally settles into a steady low idle. There is a terrible vibration resonating around the front of the car(possibly the bumper carrier beams that enter the chassis).
Try and drive the car and the revs just won't come when I want them, to set off smoothly, so all you get is vibration and lots of hesitation. The car will move slowly forward, whils you keep raising the revs by dipping the clutch…………….
i'm taking her down to D & G motors at Wath, who have a decent tuning set up, to see if they can identify the problem(s)…that's Monday 2nd Oct.
We'll see what happens from there…………..
If only I could take the running gear from my Octavia VRS and transplant it into the golf, it would drive great…………………..
Markymark
THE VIBRATION IS DOWN TO THE POLYURETHANE ENGINE MOUNTING INSERTS I FITTED(TOO HARD) WITH THE 'PROTHANE' POLYBUSHES….
I HAVE TAKEN THE HEAD OFF, THE VALVES SEEM OK AND DON'T LEAK, HAVE PUT STANDARD CAM BACK ON, CHANGED PLUGS. WILL SEE WHAT HAPPENS WHEN I PUT THE HEAD BACK ON ON MY NEXT DAY OFF.
ONE YEAR ON AND STILL NOT IN USE ARGGHH!!!! :x
MARKYMARK
Oh my god! LEAVE THE ENGINE ALONE BEFORE ANYTHING ELSE GOES WRONG! For those of you who dont know I am the owner of the afore mentioned Deutsche Mark who had this car in at our garage for 3 months. Markymark, you have neglected to tell these people that we diagnosed several faults with the engine, all your doing!! The metering head had been tampered with, cam timing was 180 degrees out, the cam shaft pulley was back to front and fuel feed and return pipes were the wrong way round (HENCE NO FUEL PRESSURE!!!). We sorted all this out and, as you mentioned, we were unable to tune it as our gas analyser was out of order for some time - Its the truth! no fobbing off required! We were told there was no rush and did our best to get it right without the analyser. We also only billed you for 2 hours labour despite the fact that we spent over 3 weeks on and off on this car. Oh and we let you take the car away from our workshop WITHOUT PAYING as we were on holiday so our employee was dealing with it. Please get in touch with me ASAP to settle the bill!!!!!! You also knew when you came to collect it that it was not where near perfect but you were happy enough to take it home anyway. I think a big old slice of humble pie is required as everything that was wrong with that car is down to your tampering. Save some pennies and leave it to the proffesionals before the engine is rendered useless.
83 Helios Blue shell/G60 build
83 1.8Gti Tintop doner car - SCRAPPED!
87 1.8GTi Quartet Cabby now on webbers all in red,daily driver
'90 Caddy Pickup
'83 1.5 Golf bare shell rebuild,knicked by pikeys for scrap
'90 Caddy Pickup
Spark + fuel + compression + everything happening at the right time
should make an engine run.
Yes I put the pulley on the wrong way around(there are timing marks on both sides-easy mistake for a novice)
Yes I put the fuel lines the wrong way around, having tried them the right way round first.
No I didn't touch the metering head. The injection assembly was removed as a whole and not dismantled at all.
I was told that the fuel relay was faulty and was replaced.
I offered to pay when I collected the car, but your mechanic said you would send me a bill for the three hours labour…….I'm still waiting…..
You send it and I'll pay it, gladly, or I'll call in sometime next week and sort it out, preferably when you are there so I can have a chat. Let me know.. :notworthy:
'90 Caddy Pickup
'90 Caddy Pickup
