Using old german head unit as a 'remote'?
The annoying thing is that there was a HU in VGC that went for less than my max bids!
FFS. I will beat the Germans eventually http://www.ebay.co.uk/itm/121048613542?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.co.uk/itm/140903675595?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.co.uk/itm/Oldtimer-Autoradio-Blaupunkt-VW-Original-Radio-Bastlergerat-/150969937310?_trksid=p2047675.l2557&ssPageName=STRK:MEWAX:IT&nma=true&si=ssWTQf669g85JdAYuKHQ0XFh6AQ%3D&orig_cvip=true&rt=nc
The last link one was nicer than the 1st link one, but it sold cheaper. Logic?! Haha I also put a higher max bid on the first link one that sold today. I must be getting despirate!!!
Last edit: by r_chez_08
the volume knob would be tricky though, unless you buy a modern head unit with a proper knob on it that way you know it does at least have some kind of pot.
have a look on google, at projects where people have made remote mounted face off projects, and basically do something similar but use the old stereo tapped into the face off connections.
it will take a lot of research and carefull work but if you really want to do it it can be done! the key is make sure your 'moden' head unit isnt reeeeealy modern i guess
http://www.ebay.co.uk/itm/Bybyte-Quad-7850-Internal-4-x-50W-AMP-BBX-1-BBN-Carputer-Car-PC-Black-Box-Nano-/200721764379?pt=US_Computer_Speakers&hash=item2ebbf3101b
Except the listing is less comprehendable!
Bidding on another radio, lost another lol!
This one is stereo and not blaupunkt, so the camper and porsche lovers should leave it alone- but it still looks pretty cool IMO.
It is on ebay Germany. The seller doesn't have paypal as an option, but they have 100% feedback with a fair few (20 or so) items sold. They have also been very willing to help, and have sent me pics etc.
Do you think a bank transfer will be safe?
Rob
If you want the PSD Boot Sticker file, it's here: Boot Sticker
Longimanus said
Why don't you get a good/old radio E.G blaupunkt stereo. Then a mp3 player or whatever and get an FM transmitter and plug that in. (I used to have one on a CD player in the boot). All you need todo then is 'tune in' to your own 'DUB FM'.
I am just going to plug my phone into the din socket on the back, thanks for the suggestion though.
Update! Finally won a radio! Cost me 25 quid. The seller allowed me to use PayPal finally too. It's stereo, and supposedly from an 82 golf. Tested it today, picked up a few stations, needs a decent aerial though as it was crackly as!
There's a small niggle, the display lights have blown, but I'll just get some leds and solder them in.
It has a 7 pin din plug. Has anyone got any ideas how to wire this into a 3.5mm jack?
Also, there is a red and blue wire coming from the back. Both power the unit, but only one is needed? They also go to different places internally? And ideas there?
It had 2 channel output, and when I tested it with a single speaker it wasn't that loud. I am going to try and wire in one of those amps I linked to above, but not sure where to start, so I am going to speak to my physics teacher.
Your best bet is one of these:
http://www.youngtimerradio-shop.de/epages/61037185.sf/de_DE/?ObjectPath=/Shops/61037185/Products/6449_02
the 7 pin DIN plug was for originally for an external device like an 8 track player, so it has the ability to switch inputs betweeen radio and source by shorting 2 of the pins. The thing in the link above has a 3.5mm input for your ipod and a switch to switch between radio and ipod - then you can keep your ipod out of the way either in the glovebox or in the under-dash tray and your radio looks completely standard (because it is)!
google translation says: Stereo adapter with switch € 24.90 Prices include VAT, plus delivery
Stereo adapter with switch for stereo car radio with 7 or 8-pin DIN connector. The switching between radio and MP3 done by a switch. Cable length 1m. Incl. 1xStereo cable 3.5mm jack to 3.5mm jack plug Note: Will not work on CD changer sockets! Item number 6449_02.
the site also sells the little plugs for plugging speaker cables in to the radio if you need some.
Hope this helps - just need to find the 25 Euro now….
Mike- Good to know that something is made. I'll have this as a last resort, but I am going to try and make something up. Thanks.
Jonny- Accessory live? Like ignition live or something, to turn it off when you turn off the key?
Here are some pics:
I cracked it open, to find lots of components :/ I truly think I would mess something up should I try and install a different amp in there. Instead, I have a new idea!
One of these:
http://www.amazon.co.uk/Speaker-Converter-High-Line-Level/dp/B004UA753G/ref=sr_1_1?s=electronics&ie=UTF8&qid=1360094249&sr=1-1
and then connect it to some of these:
http://www.amazon.co.uk/Female-Phono-Sockets-Splitter-electrosmart%C2%AE/dp/B0051F8JM0/ref=sr_1_2?s=electronics&ie=UTF8&qid=1360094348&sr=1-2
To create a 5 channel output- LF, LR, RF, RR, and Sub.
Plug the speakers into a 4 channel amp, 4x50w rms is the maximum I need, 4x40w rms should be OK. I preferably would like it to be adjustable so rears can be for fill.
Then plug the phonos for the sub into a small underseat sub or something.
What do you reccon?
TheSamba.com :: Accessories/Memorabilia/Toys - View topic - Step by Step Guide To Making Din to iPod connection
Nice little project. Keep us updated!
Here is a quick sketch wiring diagram, click on the thumbnail if there is just a grey box, click on it.
Traced some wires, and found where the two channels enter the amplifier board.could I plug these straight into an automotive speaker amp, or would I be better off using a line out converter? cheers
