Has anyone removed/rewired the fusebox
BULLETS FEMALE [ET406] - £8.45 : Hirespares.com - Supplying the hire Industry
and
BULLETS FEMALE [ET409] - £9.78 : Hirespares.com - Supplying the hire Industry
Are the two that are used in the connectors?
Edit,
It's actually cheaper to buy them from amazon as the postage on hirespares is £6!!
Please confirm:
http://www.amazon.co.uk/gp/product/B0062MIM2S/ref=ox_sc_act_title_2?ie=UTF8&smid=A1HVFGS3RZAE8D
and
http://www.amazon.co.uk/gp/product/B0062MIWW8/ref=ox_sc_act_title_1?ie=UTF8&smid=A1HVFGS3RZAE8D
For small wiring, and for coil cable!
Ta
the small ones are much more difficult, I have never managed to get them out with anything other than a proper tool! I bought a Laser 4329 kit which comes with CE1 and CE2 tools, but unfortunately its discontinued. I think they do other kits though with the same CE1 tools in but not sure which ones.
Just had a result at the breakers too, found a late mkII, went to nab the external fuse holders, and found it was a CE2, so cut the lot out
http://www.lasertools.co.uk/pis/4323_PIS.pdf
Can you see the tool in that kit?
seems to have the junior and mini timer tools in there perfect for ce2 and later mk3/4 ecu, theres the thin peg and the pick tools same as mine which are both handy. plus a couple other randoms im not sure of!
I will try to find a stockist who physically has it, so I can test it.
Will update when I know more.
Found workshopsupplies.co.uk also does the pins.
It looks a little messy, but once it's taped up it'll look good
I have the rad fan coming from fuse 1, into the far right additional relay on the fusebox ECU grounds it to close the relay, I can choose a temperature to have it coming on too
My ECU and the main relay [honda relay controls fuel pump] comes off fuse 3
Alternator on fuse 5
Digital VSS on fuse 6
Digi Dashes on fuse 17
Coil on additional fuse I call 24
Seems OK, seems to crank, can't tell you about the fuel pump as the rear harness isn't in, nor is the back end
Will update once it's all taped up!
rubjonny said
it looks very similar, basically you see the 3 on the far left? there are metal tube inserts that go into them, you can see the tube inserts in the little square cutout in the foam liner to the right side of the box. its hard to say if they're the right size tubes but I imagine so!
I have got hold of this kit, and yes those tubes fit, there's a third, longer tube which also fits the small pins! so Result!
