fuel pump relay ??
(In Topic #142369)
fuel pump relay ??
On My DX engine it's a 5 pin as one of the pins has something to do with the coil?
Sorry if that's not much help.
If you go to the electrical section at the top there is a sticky at the top that has the fuse board information.
think ill try this
http://www.ebay.co.uk/itm/Fuel-Pump-Relay-Volkswagen-Please-Check-Fitment-/380391100470?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AGolf%7CPlat_Gen%3AMK+I&hash=item5891139036
this is the one I got cheaper from ebay, arrived quickly too.
Moved this to the electrical section
ie: if god forbid you have a crash and the engine cuts out, there will be no feed from the coil and the fuel pump will stop pumping fuel which is a good thing
oh and chortle, I now found that its better to use a x-over relay 17 or 18 for a pump relay if you want to temp bypass/chec kit, fits much better in the socket
there are also 2 kinds of blade fusebox k-jet relay, those with a rev limiter inside and those without. this is the non-limiter relay from gsf:
935VG0090 k-jet relay without limiter £ 23.20
Do these relays control the cold start injector too please?
My injector isn't getting 12v on start up from cold.
And Remember, Big Smile!! Biiiig Smile!!!
Can someone please help? my car takes a long time to start up, particularly after it has been running. For example when cold probably 2 attempts then it starts. Driving the car for approximately 10 min or longer then stopping the engine, starting takes a very long time and sometimes I have to depress the throttle. Additionally most morning, I turn the ignition key on and let the fuel pump primp for a few seconds than it starts Ok. Today, I looked into the fuse box and discovered that there is a wire/connecter connected into port 18 which supposed to be for the handbrake hence explains as to why the hand brake light wasn't coming on. So I pulled the wire/connecter from port 18 and placed with a new fuse (blue=15) now the handbrake light comes on when hand brake is on and off. This now seems to have stopped the fuel pump primp and the car won't start. Plugged the wire/connector back in and then I was able to start up the car. As the car was running with the wire plugged into port 18 I pulled the wire/connecter out from port 18 and the engine stopped. Then plugged back in and attempted to turn the ignition key on now the fuel pump won't primp anymore.
Last edit: by 1989GTICabriolet
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=25972
the handbrake light black wire should get an ignition live from spade G2 or 5 round the back of the fusebox and these pins are already fused for you.
when you say port 18 what exactly do you mean?
Thank you for the email and sorry for the late reply. What I really meant by port 18 is the numeric numbers on the fuse box where the fuse goes. Not sure if that was the correct term as far fuse boxes is concerned. I'll check it tomorrow and get back to you with anything.
as i say the ignition live feed for the handbrake light pops onto G spade round the back 2 or 5, piccy here:
http://www.clubgti.com/showthread.php?219775
