Battery warning light on permanently
(In Topic #147557)
The battery warning light is on pretty much all the time on my '89 cabby gti. It does go off occasionally but never for long. I had it looked at when the car was at the garage but the battery is apparently a1 so the fault lies somewhere else. Anyone got any ideas where I should be looking?
Cheers,
Euan
What does the blue wire do? I'm not sure where it is but I'll have a look for it tomorrow.
Cheers,
Euan
If you can read this, thank a teacher,
If its in English, thank a soldier.
A soldier fights not because he hates whats in front of him, but because he loves whats behind him.
Euan
All advice is greatly appreciated!
Euan
Having trouble finding brushes to fit the regulator. Phoned 3 places today. 2 can't source for the particular model of Bosch alternator on my cabby gti and the other place took the details and said they'll let me know if they can get them.
Have found somewhere that stocks the whole regulator unit for my alternator so may just buy that if no joy with the brushes.
Also checked the wires and connections today. All seem fine. Thanks for the help up to now guys.
Any other suggestions guys?
Cheers,
Euan
Cheers,
Euan
Is that properly connected?
Ta,
Euan
trace it from there carefully, make sure its not earthed anywhere, and it is run to the D+ terminal on the alternator not to one of the other random studs
Thats me now tried a new regulator, new blue wire and its connectors. All connections seem ok. If the alternator was dud then the car wouldn't be able to drive far but I've had
it on a couple of decent journeys lately with no problems.
Any suggestions welcome!
I took mine out and gave the contacts on the blue ribbon a clean, then put a couple of turns of insulating tape over the plastic bit, then dropped the blue ribbon over and re connected.
The tape just bulks out so the contacts are fully touching.
Any other suggestions are welcome!
Also while I'm begging for help, anyone got a suggestion on the easiest way to get the interior light wires down to the switch at the drivers door. My wiring was missing on the drivers side so I've got a new wire and connectors ready but it won't feed through! Tried pushing thick strimmer wire along the cavity above the windscreen to act as a guide but it gets stuck at the corner of the windscreen. Played about with it for over an hour. Don't really want to have to start taking the car apart if possible! Anyone got experience of doing this?
Cheers,
Euan
The wire wasn't that visible to be honest.
