Anybody know what this plug is for?
(In Topic #162628)
____
From a 1983 1.8 gti engine, looking at the car, the plug is located just behind the battery and air regulator, almost near the brake servo. Comes from out of a main wiring loom. I cannot see any obvious places it needs plugging in.
Also, it appears I have something missing. There is a 2 pin sensor and I have 2 of these attached to the brake 'outlets', one immediately out of the servo (that is connected and assume is my brake lights) and this one that is at the end of the manifold, not connected. I cannot see any missing plugs or connections that are obvious. Thanks.
end of the manifold one sounds like 5th injector? is it blue?
The end of the manifold is just a 2 pin sensor, so its the male end of the spade connector so it has no colours on it. The manifold is the brake manifold.
Whats the reason for two? And how are they wired? Thanks for the help!
Is there a similar one located on the other side of the engine bay near the 5th injector?
It sounds like it could be the spare for side repeaters. Try putting a circuit tester through it and put you indicators on see if it lights up. I know they don't have the side repeaters but mine has a spare connector in that location coming out of the loom for repeaters. It would make any future vw changes easier if the wiring is already in place. That's why they sometimes put extra in.
Hope this helps.
