mk1 golf GTi electrical problems lights mainly!!
Your problem is either most likely:
Switch
Fuse
Big power resistor that sits in the motor (part of the motor loom)
or motor seized
Either way I've got all those bits to fix it
Rich
ive also found that i have the D/S door check strap and the pin, it was just shoved back into its recess in the door, and i couldnt see it due to the plastic cover thing!! so ive got that all greased up and fitted, so the door dont swing back and hit me eveythime i get in to me car slowly! (dam drive on a hill!!!)
as far as the blower goes, i took a look under the black plastic scuttle pannel, and removed the cage around the motor, the fan moves freely, so im guessing it aint seized, there is a big resistor thing on the front of it tho, dunno how to test to see if thats working, all the wireing looks fine, good tight conections etc,
deffinalty not a fuse tho, so its gonna be that resistor or the swich so if you have any tips let me know!
alex.
did you get my locks mate???
let me know
alex
P.S whats with the times shown on this fourm???
Yes locks here this AM - I'll get that hatch surround off to you and your exchange rebate on the locks.
There are four wires on the back of the switch?
One should be the live feed and three others feed to the motor for the three speeds. I'd verify this with a meter.
You could just check the switch this way also with a meter.
Rich
ive had the swich off, and it has a black round plug with 4 blade terminals ive put some blade connetors down all 4, and one by one i conneted a wire between em, nothing happend, that was with the car on 3rd click on the ignition, so it should have done somthing, but it didnt,
all fuses are fine,
so do you recon its that resistor thingyer me bob?
how much would you want for a working one???
ill be needing some of the bits i taked on the phone to you about soon anyway, im gonna get me a job fisrt tho!!!
alex.
