(In Topic #216865)
Thanks in advance dean
Sent from my SM-G903F using Tapatalk
Are you talking about converting it to an Electric Roof?
Sent from my Smartphone
When they go bad or bend the tops are a wee bit lopsided if they go one side bad.
The tops are wieldy to open and after you get half way, they fold really really fast.
Closing requires 2 people.
The Power Tops have Hydraulic rams, a motor and some safety switches. Rams leak, motor impellers fail, and safety switch prevent the top from opening or closing.
All in all I prefer manual.
I never understood why the UK has so many power tops, but so little power steering.
And don’t forget so little sunshine. To take my top off I will use an angle grinderBriano1234 said
There are gas struts on the Manual opening tops that assist you in raising the top all by yourself.
So the best thing to ask Carl chortle as he's the Guru on them.
Might take a while to get a reply because he's just started his own business fitting new tops, repairs and everything to do with Cabrio roofs.
We wish him the very best of luck with his business!
Golf Cabrio said
I'm definitely no subject expert but I seem to recall that the whole frame in different but please don't hold me to that.
BS. and they "the frames" are different.
Yeppers, lots of Labor in that job….
But then again when a Auto Upholstery shop quoted me on 500 dollars per seat to re-do the Seat Back front Center section on my Cabby……. I thought for a quick minute about starting my own business….
So i just do tops for a quick few quid…
Briano1234
"BS"?
Hi Brian I'm not sure what you mean by that, please explain because in English, English it has a meaning which is unpleasant!
BS as in Bull Shipper, what did you think I meant. "No Subject matter expert" my Fat Aunt Fanny. You know more than you let on about.Golf Cabrio said
Briano1234Briano1234 said
"BS"?
Last edit: by Briano1234
If you look here picture 13 shows it.
View topic: .How To Replace that Cabriolet Hood . - The Mk1 Golf Owners Club
Little effort and in controlled fashion..
An image of the metal action could help with its geometry and movement.
Gently but with correct continuous even movement until upright then pause…
Move towards boot and encourage gently the hinge operatic should begin the fold back down.
( IF NOT DOWN THEN ..LITTLE.. MORE BACKWARD MOVEMENT)
ONLY gently.
When moving down use very little effort but even on the back and spread even with steady pair of hands until almost there.*
Once almost in stow position check both sides appear even and use only a little more to form a complete fold.
Now it's ready to check the engagement of the lock.
From one side push down gently, one hand at rear to even pressure until you hear or see latch pop lock same to other side.
To close use latch open one side then t'other side.
From boot spread hands apart and even lift up and up forward slightly.
SLOWLY.
ONCE ALMOST UP CHECK IT'S NOT STRESSED.
then top front should be way up and ready to move to screen.
If it moves front more it's ok as long as you notice it's fluid curve as it begins to settle.
May finish 3" above screen.
Get in and carefully pull little lever down effort here as it's no longer moving forward.
Pull down only with handle hook in ready position …
Latch one side up. Then t.other side.
The more confident you are in being gently and steady the less effort you need.
IF YOU FEEL IT'S A STRUGGLE
STOP .
It may not be ready to move in that direction yet.
Ps I don't drive on a motorway or long disrance with it down.
Personally I think get there get it down with friends then enjoy sunshine.
Any advice on this please pm me to edit.
Post from a ' HOP X DUB '
What's next?
Mk1 second project cabriolet
MK1 first project cabriolet
Full of hints and things.
Also were can you get the new 3d decals the vw badges golf cabriolet etc thankyou for the warm welcome
As long as the covers on it fine, that's the reason we have a cabriolet, get the roof down as often as you can, that is what a cabriolet is all about…. If the roof wears out buy a new one £200 is cheap for a convertible top.
A wind blocker helps a lot so get one then you can drive at motorway speeds with the roof down and not get your head blown off!
