Tintop GTI history A576 UDM. JUST SAVED /
(In Topic #218932)
Anyone know anything about this rolling shell just bought. Hopefully saved
I little bit of work needed there…..
Odd place to put the fuel filter when the engine was in there, right next to the heater blower you would not want any fuel leaks there, nice big hole into the cabin for fumes or flames!
Strange in the lasted pictures the scuttle has been cut out..
I've bought it how is in last photos
They tryied smooth bulk head
Not sure what going do with bulkhead they wrecked it I think
Thinking putting a tt under it.
I think be easier fix swapping body's
I've got all the receipts lot money spent with some of the photos. Not seen some them posted Just shame being stripped so much
Yes aerial hole still in roof as well.
I'm just sad bulkhead being hacked no.id number anymore Going get bit plate stamped and welded in somewhere
Not going start for yr or so need finish caddy pickup
Was on eBay £850. I give quarter that
Fup me what happened to this car ? Seen it for sale a few years back for either6 or 8 k , and I thought to myself this looked tidier / finished better than my car which has over 10k put into it. The bahn brenner sounds crazy
Going start making a start soon
I've already fitted glass and roof to keep it dry
Just bought a mk4 golf gti 18 turbo AUM running gear to drop in
Does any one know someone can do imm delete on ecu
Save fitting full harness and clocks
I'm just wondering how to bolt in steering coloum since bulk head being smoothed no holes in sight
Don't really want weld in coloum
I'm doing conversion from mk4 golf gti
Got coloum and frame from that do I just fit this
Regional Host NE
thought you were going to pop
over and make yourself a template
mate
Made start today blasted bulk head try sort out
Started putting bulkhead back in to car
Not much but every little bit helps
Little bit now now I've put holes back in bulk head fitted mk2 golf heater box
Door post repaired where hinge was chopped off
Power steering rack bracket done and fitted
Mk4 golf servo fitted to bulk head with clutch cylinder
Was bit of pain with the mk4 golf adjustable column fitted
Mk1 golf fuel tank modified take mk4 golf gti tank unit
Mk4 golf full harness just about all in
It's bulk head what took time to repair I add photos later date
My goal was get it running by Xmas but always next year
Feel like starting get somewhere floors, sills, chassis axle mounts inner and outer wheel all done
