Roof fitting to 87 golf convertible. WHere? Mohair or Vinyl?
(In Topic #193141)
I need a new roof fitted to my 87 golf convertible. does anyone know any good company that does it cheap or anyone on here could do it? I found a company that does a Vinyl roof for 640 with fitting? is it a good price? also what is better? mohair or vinyl?
Thanks, help appreciated
Hi Tomi
Carl chortle on here is your man to talk to. He's not the closest to you so may not travel - I don't know - but definitely send him a message and have a chat.
Having had a roof done by him I can understand why a. some companies wont touch these now and b. why some companies wont do it right! He did a cracking job on mine
These are the people I bought the hood from - http://www.car-hood.co.uk/golf-mk12-h1102
Mohair is much nicer than vinyl and worth the extra money, although if it's a daily driver and not garaged I would probably go for vinyl as the mohair can be a pain to keep clean.
Mohair for looks, Vinyl for easy to keep but whatever
chortle
, your Man!
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=chat%2Fgeneral-chat_3%2Fmohair-roof&keep_refreshed_once=1
i had this quote for a vinyl and mohair fitted.. im lincoln way but if you want to try a bulk buy and fit ill send you contact details. im looking for tan mohair this month.
On the drive
Myvalver 89 GTi Grey mk2 16v
Whatever you end up doing, replace the foam seals, the side tension cables and the rear tension cable - all will be past it.
Plus make sure you have new loops for the tonneau cover to fit in and if you don't use Chortle to fit it, make sure who does knows where to position them (kind of inline with the rear corner of the car) as you see a lot in the wrong place.
Finally, be prepared for other items, such as it will be quite likely that your rear window frame could be rotten and will need repair/replacing.
….here's a pic that shows where the tonneau tabs should go
Don't the taps fit in line with the hooks of the roof cover? Mine are further in than those in the pictures as I don't think I could fit and hook down the rear of the my cover if they was there?
I'm pretty sure the vinyl roof on my Cabrio is still the original factory fit. The tabs are inset about another 1cm from the pic above.
Ah ok, these do line up with the hooks on the tonneau cover ok. I wonder if the hooks moved on later cars? I know early tonneaus didn't have as many popper clips on them?
Life Member
That's odd. If they were inboard they wouldn't have lined up with the tonneau hooks
