Mk1 Golf GTI Reverse light Switch
(In Topic #216527)
Now Working Lights
As my MOT is due next week I decided to tackle it again, and not sure how I managed it but I have adapted the 3 pin type to fit the 2 pin type. Firstly I fiddled with a multi meter until I got a circuit between 2 pairs of pins, and found a pair that worked.
Hopefully with some pictures you will see from the pictures what I mean. The old one at the bottom showing the 2 sets of connections.
The new one at the top I found a circuit between 31-3 and 15-R. So \I then carefully pulled back the rubber boot and exposed the plug and accordingly moved the connections to the corresponding pins, Like this.
This is how the connections were when I pulled the rubber boot back. The bottom 2 are the reverse wires. I used a set of small tweesers to push a small tab down and pull the wires out. The Pic below shows how I connected them in the new switch. Result is Working Reverse Lights !
MK1 Golf GTI 1900
MK2 Jetta GTI 16V
MK2 Jetta GTI 16V
Well done on fixin it tho!!
MK1 Golf GTI 1900
MK2 Jetta GTI 16V
MK2 Jetta GTI 16V
Reverse lights will have to be checked then.
Good job on getting the switch working
