crazy quiffs three point cabby rear belts ?
As an indication the kit will be in the region of £150 (incl VAT) for the two brackets - belts can be got new, used or you can sort your own. We will be using 4 door front belts - assuming the clasps will work. Rear hatch belts are no good as the inertia unit sits at an angle.
Our kit will be bolt-in (no welding) but a notch out of the rear parcel shelf side support will be required - dremel or similar. The original VW units required this also. This to to get the belt as close to the side of the car as poss. Your parcel shelf will also require a cut out for the bracket to protrude. We'll provide templates for all of that.
I'm interested in your feedback on pricing and fitting.
Rich
as in £150 gets me all that i need to have rear seat belts in the back of the golf
ta marc
Life Member
Jon.
crazyquiff said
razor344 said
so is it £150 with the belts ??
Marc - it's £150 excluding belts - we'd do used ones for £25/pair
thanks for that
what belts do i need to look for
mk1 ??
ta marc
razor344 said
thanks for that
mk1 ??
ta marc
Probably Mk1 4 door fronts but I need to check a coupe of things out first.
Rich
funk-star said
How are you getting this approved/checked/tested?
Mark - we don't plan to test this item. If we did it would make this small batch production item far too expensive and would stop is in it tracks.
What I will say is that we have based the bracket heavily in VW's design and have made it significantly stronger. That way we can be sure that it is robust enough for the job (VW would have crash tested it) yet be cost effective.
Rich
I gave up with my design due to the testing issues and was curious.
ta marc
I've spoken to our "guinea pig" customer and they have it fitted up and are using it with their child seat. They said that the garage that fitted it reported that they were well made fitted well and they could hang the car off them if they wanted - so plenty strong enough!!
We are ready to take orders for the first batch of say 10 car sets. Pricing is £150 per pair + £25 for a pair of seat belts (used - when available). Kit will include the brackets, nuts and bolts, fitting instructions and templates.
This will be done as a first come, first served basis - delivery is estimated for the end of November. We can also fit them to your car if required (costs and times on this TBA).
If you would like to order a set please contact us - http://www.golfmk1.co.uk/AboutUs.htm so we can take your details and a £30 deposit.
Rich
