Wheel stud conversion
Has anyone done a wheel bolt to stud conversion to their cars?
I've got some wheels that need studs and won't work with bolts. I know I need to run Cragar bolts and off set washers but I also need studs and that's where I'm confused.
Any problems, advice or places to buy would be appreciated.
ta
Ian ;)
Cornish Host.
1980 VW Derby
Clive the Cabby
Ujum the Invisible
Mynx the  Tintop
I stumbled across a thread on a guy doing a stud conversion to his mk5 golf a while ago… Umm
 :ocf_emoticons__eusa_boohoo:Elevator music
Thought I might stud the daily just so I can run those silly colourfully-anodised nuts  :lol:.
:ocf_emoticons__eusa_boohoo:More elevator music
FOUND IT
http://golfmk5.com/forums/showthread.php?t=76992&highlight=stud
Although off the top of my head I dont know if the thread is the same on a mk1, but the theory is the same
Edit:
Had a bit of a crafty google, the thread you want is m12x1.5 so these would work:
http://www.elite-d.co.uk/race-wheel-stud-conversion-kit-m12-x-1-5-early-volkswagen/
Bulletnose might be a bit excessive for daily use though. I think the theory is a bit of space to play with before thread starts, but whether you'd need/want that is  :ocf_emoticons__dontknow:.
Edit 2:
Larkspeed seem to do "normal" studs, without the bulletnose:
https://www.larkspeed.com/index.pl?c=WHEELSTUDS&s=category
And thinking about it, I think that DIY thread shows tightening with an alan key… That's probably not a good idea for getting a proper torque. Standard 2 nuts locked together & torque wrench might be a better bet. Would hate to see those lovely looking Cragars rolling past you on the dual carriageway :thumbs:.
Edit 3:
While feverently re-researching the whole wheel studs thing, I stumbled across a little blurb on american spec wheels requiring sleeve-nuts (or tube-nuts, whatever the americanish translation is) though quite why, I'm still none the wiser… :ocf_emoticons__dontknow: I imagine that's why you need Cragar-specific fixings.
Last edit: by benr
Cheers mucker.
I like the elevator musak by the way.  :lol:
that's a lot of info. Still non the wiser! Thanks though.
Ian
Cornish Host.
1980 VW Derby
Clive the Cabby
Ujum the Invisible
Mynx the  Tintop
Yea I thought that as I was journeying through the internets. Lots and lots forum debates and faux-official opinions, yet very little in proper research or anything  :dry: although there does seem to be consensus that for racing applications you need splined hubs and studs. But screw-in types… :ocf_emoticons__dontknow:probably a case of not seeing the wood for the trees.
And I'm still none the wiser as to what a sleeve nut is, when not holding fluid lines together.
