Mk1 cabby HELP!!!
(In Topic #166975)
It's all gone wrong :(
rubjonny said
alternator belt also runs your waterpump! you have now blown your headgasket I think
what Rubjonny said!
Not a nice job nor very easy.
If look for a replacement engine.
Next remove your spark plugs and turn the engien over till the cam is lined up to TDC, loosen the tensioner and slip the belt off the cam. Then undo the bolts holdign the carb to the inlet and move it over to the side out of the way, you dont even have to take any pipes or cables off it except the coolant pipe on the side to the inlet if its still runnign a 2e2 carb. Finally just a couple coolant pipes and wires on the head to undo, and after that all it comes down to is 10 spline head bolts and off it comes!
then its a case of get a new head or have the old one skimmed by a local machine shop, main thing to be aware of on reassembly is that the dizzy can spin freely once the belt is loose so be sure to put it back to TDC before you put the head back on.
first thing to do is buy a brown mk1 haynes manual, its awesome. get yourself onto ebay should be able to get one cheap mine was 99p
Am i really looking at a new engine / gearbox at this stage and what sort of money would i be looking at for that work to be carried out, its a but beyond my skill set and tooling.
I would put up a wanted for help local to you, replacement engine by a garage would likely cost you a packet and doubtful they would do a good job compared to a clued up mk1 enthusiast!
money wise depends what engine you want to put in, coudl go for something a bit beefier over std maybe a 2.0 bottom end. the basic 2.0 lump can be had for under 50 quid, then you would need a new known good head to be safe plus a TSR adaptor ring for the dizzy if you want to run it on the old managment.
maybe a 16v? 2.0 16v ABF lumps go lovely in mk1s
