MFA oil temperature
(In Topic #192152)
I noticed the oil temp sensor on top of the cooler/filter had no wire attached which is probably the reason for the MFA not showing the temp!
i can't see any wires in the engine bay so will need to run one, what i am looking for is info on what wire on the clocks needs to connect to the newly run wire?
Thanks in advance
I can't answer that question but I think I might know someone who can!
Calling rubjonny
if not look at the wiring behind the fusebox for a yellow or green/black fly lead from the dash loom to the engine loom, it should be a male spade on the dash loom to a female spade on the engine loom. if its yellow then this is for the oil pressure switch, and the oil temp is going thru the fusebox. if green/black this is the oil temp wire
