H&R Anti roll Bar Upgrade
(In Topic #224209)
Advice Needed
Has anyone fitted the H&R sets as looking at the images they are different in how they fix to the axle and front wishbones as it looks like they bolt on and not sit in the standard bushed clamps?
Plus is anyone running them and how good they are??
Thanks, Andy
Taking them off is one thing, getting them back on is another…. Hint they are easy off and a pain to put on….
IIRC I took the ends off first as that unloads the things, but getting them back on was a bother, but I had the tool, a 2 foot Square Steel tube, that I could slip over the end to get it into position. One side will be easy as it isn't under load, it is trying to PRY the other side in that is the usual issue I have found.
Years ago when I was using my Diesel Golf as a work car, I found a set of butt sagging helper springs that I added to my Golf, these were great at keeping the car level to the road when the rear was loaded with people or luggage/ parts…. I would see tons of Dubs running down the road with the bottoms dragging at the rear, and when I chose to buy a Golf as a work car the first thing I bought was a rear end sag preventer….Can't find them now but they could be made easily enough… The clamped at the axle beam triangle plate wher ethe trailing arms attached, then bolted to the Body at the back end with nuts, bushes washers and a double ended link…
looked something like this:
No stock at Venom Motorsports anyway so looks like the back one's gonna get a good dose of sanding and painting!!
