fuel pump
(In Topic #197859)
20v turbo
I had to change my supply pipes to 8mm internal diameter as mine was originally a 1300 small block.
I have a redtop facet feeding a 1 litre swirl pot. Then my bosch 044 feeds my fuel rail from there.
Sounds like you have other issues!
My pump was noisy and poor fuel delivery but still drove ok. (Till it totally packed in)
later cars with bigger fuel tanks (space saver wheels) also have a lift pump in the tank.
http://www.ebay.co.uk/itm/VW-Golf-MK1-1-6-1-8-GTi-1976-1993-New-5-Bar-In-Line-Fuel-Pump-/181369864965?pt=LH_DefaultDomain_3&fits=Model%3AGolf&hash=item2a3a7c8305
thanks guys
Ill ask on the page "mk1 golf 20v conversion" page" some cleaver guys on there with this conversion.
Last edit: by mk1 daz
Maybe swap the loom first.
Can you check voltage pulses at the coil pack connections?
About £40 from tps.
If someone suggested if it's an agu it can be the ignition amplifier.
i have swapped coil packs around with once known working .
iv swapped the coil packs not sparking to the cylinders sparking and they spark . so coil packs are all good .
iv brand new plugs in and still no spark .
so the loom . the coil packs . the plugs . are known to all be good . so from the icm to the ecu lies the fault so doubt been ecu and not wanting to play with that so will try a new icm if solves it ace if not car will go on ebay
(A reply from Facebook)
whittleos said
dose the auq engine use the same icm control unit ?
I'm not sure but ive asked 👍🏻
