Advice on expected power output
(In Topic #200758)
I recently got my car dynoed and was slightly disappointed with the results considering the engine its running. I want some advice as to next steps, what to check as to why the possible poor performance or if indeed this is the expected output from the engine.
Engine:
2l 16v - 6A bottom end and KR head. Rebuilt around 7k ago, new pistons.
Ported and polished head.
KR Cams
Twin Dellorto 40's
4-1 manifold
2.5" jetex exhaust
Facet fuel pump and filter kings regulator.
I would expect around 150bhp, is this unreasonable? However on readout I got 115bhp with a good power curve and strong line.
Car runs fine no issues, is it worth getting a compression test done? Is it fueling, twin 40's too small?
2l abf block
kr head with aggressive cam
4-1
jetex 2.5 race exhaust.
i would expect it to be running a bit more the that. but there is a different between BHP at the wheels rather then BHP at the fly. but some one more knowledgable will be able to give you a better answer .
abfmk1 bfmk1 yes, you might be right here. Following the dyno the chap who did it said that he was surprised the workshop wasnt full of fumes and thought that the car was to lean which might explain a fueling issue. Its running 38mm chokes I need to check the other size jets.
