Abf engine mounts
Hey all
all just started doing an abf conversion. I've had the mount on the drivers side moved into place as it was a smallblock. But when all bolted up to the rear gearbox mount it seems to tilt the engine forward and just doesn't look right. Sorry if its a bit vague but am new to all this. Wll try get some pics in a bit
the bracket has to be flipped upside down before welding back on just to double check?
The mount you showed is in the same position as yours. I bought a big block on and fitted it. It's when the rear/lower gearbox mount is connected it sits pretty much at the front of the mount in the
