Wolfsburg Steering Wheel
(In Topic #150394)
Morning guys,
I am after a bit of help with my recent purchase a Wolfsburg steering wheel. Overall it's in really good nick but being completely new to these wheels I am a bit confused about the centre. It seems to come away from the wheel very easily. Looking at it I think it should be held in place by 4 plastic clips which appear to have come off. Also what about the horn??
Any advice on how I can repair this please.
Mines the same dude, it should have 4 clips like you say, Mine has got two of the clips, and the other two have got screws in which kind of hook into the holes on the steering wheel and hold it in place.
Its a bit rubbish but I think its pretty common on these wheels. I can't help you with the horn as mine is on a button on the dash.
The horn should work as the copper ont the centre and the brass on the wheel contact each other and te wire goes to the wheel part. If needs be il strip mine later for pics if you like its in the kitchen
If you could Brad just to give me an idea of what a complete one should look like to compare it to so I can work out what needs doing.
Cheers.
Nay problem. Il post pics in here for you
Top man thanks a lot
Life Member
dubboy said
Yes, your clips are broken. They break easily when numpties pull off the horn centre. Each clip should also have a spring on the outside of it for the horn switch action.
I don't suppose these can be bought from VW now can they?
jellybelly said
you are also missing the copper ring off the rear of the wheel
to make contact for the horn to work
Again I'm guessing these have long since been deleted by VW and can't be got JB?
jellybelly said
i should imagin so dude
your horn will never work without the ring on the rear
what did you pay for it mate? if you dont mind me asking
Paid £60 for it. The actual wheel is in good nick. Looking at it again I think there is a copper ring around the middle? Have a close look.
Right, looks like your missing the copper ring from the under side of the wheel
And looks like you have the one on the top, but not the clips like so,
if you haven't got that copper but you can get to back to make something to suit the job? Bit off fabbing
By removing the plastic cover like so,
But you can't do anything with the clips I'm afraid.
jellybelly said
i could be wrong, but can't make it out in the photos
NO you are correct mate as ever
Whats the best bet for bits then? Quiffs or am I totally screwed?
Many thanks Brad for taking the time to upload some pics.
jellybelly said
buy another, you might be able to use a copper ring off your old wheel as they should all be the same diameter
You mean another Wolfsburg? They're at least £125 on eBay uk
No worries! Have a button instead
Might have to be mate. Or just stick with the cack one I have at the moment and put this one in the shed for another year. I'll take it up to JonP next time I am working on the car and see if anything can be done to it
