Saggy Doors
(In Topic #164295)
Hi Gents,
As the title suggests my Mk1 has saggy doors, so much so you can notice the mis-aligned side stripes.
I have tried fitting new striker pins and have had to fit new locking mechanism but this does not help.
Does anyone know if there is a proven method of getting them to line back up properly?
Thanks Bob.
Thanks Bob.
Mk1 golf gti campaign… 16v ish…
MK3 gti 16v
is the mk1 rusty? depends what you mean by rust….
MK3 gti 16v
following an over enthusiastic opening , the drivers door on my mk1 caddy decided to drop at the tail by quite a large margin. a good manly upward "tweak" to the rear edge with the door just open soon brought things nicely back into alignment! lift the door at the bottom with a big wad of rag (to save your skin or paint….depending which needs protecting the most!). assuming your door has drooped at the rear , this may be worth a go?
could be the door hinges are worn, not a fun job. lower one is usually the one that goes.
