refitting my wings help please
Hi all so i`m about to put my wings back on my cabrio my question is I know they are sealed Down the A pillars but do I put sealer on the A pillars first then wing then bolts tighten then more sealer. Or should I be fitting wing first then sealer.
Thanks for any help as I just for the life of me can`t remember.Hi all so i`m about to put my wings back on my cabrio my question is I know they are sealed Down the A pillars but do I put sealer on the A pillars first then wing then bolts tighten then more sealer. Or should I be fitting wing first then sealer.
I would not use anything to seal them, there is a splash guard in the way so you don't see it anyway, if you need to remove the wings again it makes it alot easier to remove.
"I would not use anything to seal them, there is a splash guard in the way so you don't see it anyway, if you need to remove the wings again it makes it alot easier to remov"
Thanks mark1gls but im wanting to seal them as oem.
and water will get past splash guards as there not water tight.so my fist question still stands if anyone can help
thanks agian mark1gls  :cool:
I'd say sealer on the A pillar first mate, then more if you think you need it.
Craig.
'83 Tin top with MK2 16v conversion and bike carbs.
