Cabriolet Leaking
(In Topic #147733)
Cabriolet Leaking
I'm looking on advice on where to start to stop a leak on my golf. It leaks at the front onto both seats. The leak looks like it comes from near the roof handle area on both sides. Could it be that the windscreen to roof seal has perished during its life?
COTM Team
aircooled1968 said
its prob down to the roof foam gaskets, they perish over time and its a common thing, pm chortle he may have a set
chris
Thanks Chris.
I will pm chortle, Which part is it though, do you have a picture?
COTM Team
88gticab said
chris
Thanks Chris.
no sorry but im sure carl will (chortle) he the god of cabby on here
chris
What happened in the end pal?
My Cabby does the same thing!
Cheers,
Zack
COTM Team
Cabriolet Leaking
Generally it's the foam gasket seals that go.
Plus as Bob points out re applying silicone to the header seal often helps.
You need to check also how far the header on the frame sits against the seal. So adjusting the J hooks to pull in tighter usually helps.
I have plenty if seals here and can e mail a fitting guide also.
Just send me a message here.
Chortle
I am about to refit new headliner, padding bag and sonneland roof and didn't realise the foam seal was required. Do you have a set and how much is the full set please.
Regards
Graeme
Cabriolet Leaking
I can help send me a message on here please so I can sort it out for you.
Many thanks Chortle. If you can let me know what I need to supply and how I ca n pay you I'd be grateful.chortle said
Cheers Rich,
Graeme
I'll find out the size if any good to anyone?
I've had a thought after watching one of the wheeler dealer episodes, wasn't the golf one but Ed used some rubber tubing, bit like fuel line to pack a seal out on a door by sliding it up through the seal. It did work and I can see that it might work for us. Chortle have you done this before and what are your thoughts?
Cabriolet Leaking
Not had a message from you mate.
Daniel
Ok you can double the foam gasket seals at the front to lower the seal against the glass.
I was going to say take the door card off and use the adjuster with the mechanism to raise the glass slightly.
Did you reapply the sealant before you replaced the seals?
Have you adjusted the J hooks at the front to pull the header in tighter against the header seal?
Have you reapplied sealant to the front header seal especially the knuckle area outer edges?
All leaking points.
Chortle
Sorry been on holiday fr the past week, can you see my responses?
Not sure if I am responding correctly
Regards
Graeme
