will it start first time?
would like to give some advice with your problem but haven't got the experience with VW engines yet ops:
you getting the right amount of fuel to the injectors? (Stab in the dark :wink: )
You may already have a copy, but I have a Bosch fuel injection manual which I could e-mail you. Much better than the Haynes. The valve on the side governs the fuel pressure in the metering head, not sure how easy to remove and refit without effecting set-up. Have you checked the sensor plate set-up, gapping and movement?
Are you using Prowlers injector test method to test fuel flow? If not how are you checking the system?
1983 1100 C
1983 1100 C
Will also give me a chance to properly check the spray patterns.
Can someone tell me…
How much fuel should I get (from the injectors, not directly from the pump) and over how long (litres/minutes???)
My Build Thread
markwon said
not sure if a 1800 one willl work on a 1600 engine - different parts codes?
They are different Part No's. I checked while looking for another to try on mine.
Mk1 1.8 and Mk2 1.8 8valves are the same however…
AL.
My Build Thread
From my own experience and reading ChrisB posts you really need a pressure testing kit to properly test compenants such as the metering head, unless you can swap over with ones you know definetly work.
1983 1100 C
1983 1100 C
markwon said
When carrying out the test you should move the sensor plate back and forth through its travel looking for flats sport or inconsistent fuelling form the injectors.
Ah right - will do then…
As for swapping the metering head - I haven't actuall tried 8 on the car LOL… I have just had 3 on and off (Cleaning etc) a lot!!!!
My Build Thread
1983 1100 C
1983 1100 C
markwon said
sticky or incorrectly set up plate can be the culprit, bear in mind in operatoin the plate has to be free moving enough to be lifted by engine induction.
Plate is free moving and nice and clean too!
My Build Thread
this is all getting quite complicated and possibly expensive!
not sure on how much fuel over what time but as Markwon's suggested Prowlers test shows that when one injector reaches 100ml of fuel, the others should be AT LEAST 85, I think it would take about a year to get that much fuel through my injectors at the moment :cry:
think I'll see if I can get my mates off him for nothing as a spare and try to fix mine!
Apologies if you have already done this, but have you checked the delivery rate from the fuel pump by disconnecting at the fuel filter and measuring output into a bucket over 30 secs? If all ok, then metering head is failing to pressurise properly. This might not mean the heads damaged, but possibly the main valve has been messed up by removal and needs setting up again? To do this you need a pressure testing kit - ?40 from the USA.
Probably stating the obvious here :roll: quickest and easiest way to eliminate metering head is to swap for one you know will work.
1983 1100 C
1983 1100 C
there's definately good pressure (not sure on the delivery rate though) from the fuel supply before and after the filter, to and from the warm up regulator, to the 5th injector and to the fuel return pipe.
haven't touched the mixture screw either :?
when you say the main valve do you mean the one at the bottom of the metering head? this did have a stiff point so i stripped it out, cleaned it with new fuel and replaced it which done the trick until I tried firing the car up where it went stiff again!
Is there some sort of small valve on each of the outlets to the injectors? I get no pressure on the outlet to injector 1, and very little pressure on the rest
If any of that makes sense!
Do prowlers injector test manually lifting the air flap - If fuel now comes out of the injectors (assuming injectors are not blocked) then the plunger is sticking not allowing the air flap to rise. If it still no fuel from injectors it is likely the metering head is gummed up and the orifices are blocked. Only way to sort is to dismantle and clean or replace!
FYI…
I looked at them on mine. I totally removed one of them and then realised "What if it wasn't all of the way in in the first place - I won't know how far to screw it back…"
On checking the rest, they were all 2 and a quarter turns out from the fully seated position.
My Build Thread
i did take one of the allen key caps off (the rest where on so tight I couldn't move them) but didn't touch the one inside it
If that doesn't work I'll strip it all down, clean and see if it's fixed it.. hopefully my mate's going to dig out his tonight for me.. can't let things like that go to waste :wink:
Best way to test the system is follow Prowlers method. Without lifting the sensor plate you can't really assess fuel delivery. Is also best and safest to test without engine running and with switch wired into fusebox. Makes testing a lot easier and safer 8O .
1983 1100 C
1983 1100 C
The nature of the K-Jetronic system is such that a healthy VW-intended system will work on almost any engine size from 1.5 to about 2.1 litres, because the amount of air flowing in (and the resulting porportion of fuel that is delivered) is directly dependent on the capacity of the engine, so the system is fairly self-adjusting…
Is there any Bosch specialist's or the like I could take the original to to get repaired? going by the prices a new unit is it would be good to have a good spare.
I'll let you know how it goes
1983 1100 C
1983 1100 C
lets just hope it solves the problem this afternoon!
