Water leak
(In Topic #198891)
I changed the coolant on my Mk1 GTi Cabby at the weekend, drained the coolant by removing the bottom radiator hose as usual. However I noticed a small coolant puddle under the car this morning. On closer inspection, the leak is between the thermostat housing and the water pump. So, naturally I looked at tightening the two housing bolts, but it looks as though some ham-fisted previous owner has stripped the thread on one of the bolts! My removing the bottom hose must have disturbed it. I can tighten it so far, but I'm obviously not too happy about driving around with a potential failure of the housing bolts. My question is, does this require a new water pump, or is the threaded hole in the pump long enough to fit a longer bolt through and secure it on the other side with a nut?
if it's the plastic type the leak may be from the housing so my be worth fitting a new one and you may be lucky and it bolts threads are stripped not the water pump if so fit some new bolts. Have you removed the bolts to check there condition, you may be able to remove one at a time so not to disturb the housing
You will need to fit a new rubber O ring seal if you remove the housing, it's worth checking that a new one comes with the seal.
http://www.ebay.co.uk/itm/THERMOSTAT-HOUSING-NEW-1-6-1-8-1-9-2-0-TRANSPORTER-T4-GOLF-MK1-SCIROCCO-CADDY-/351446609577?pt=LH_DefaultDomain_3&fits=Model%3AGolf&hash=item51d3d9aea9
When you change your coolant it's best to remove the thermostat to drain the water from the engine as just taking the hose off from the bottom of the radiator will only drain the radiator.
O ring gasket/seal.
http://www.eurocarparts.com/thermostat-housings-gasket
Rear bolt hole
Front bolt hole
Lengh of standard bolt
You can have a problem getting the housing past this bit of the engine block but with a bit of twisting and wobbling it will come out.
When I drained just the radiator I got 3 litres of antifreeze out and when I took the thermostat out a further 2 litres came out that why its a good idea to drain the engine and well as the radiator when changing the coolant.
1992 Sportline Cabriolet in Red
2 tintops.
3 cabbies, 1 with G60 power, just for fun.
Volvo T5, just for fun.
3.1Ltr V6 Dutton Leggera, just for fun.
Renault 5 GT Turbo, just a money pit!
Several boring cars, just no fun!
