USDM 83 Rabbit GTI Idle Control Valve issues
(In Topic #182891)
It's listed there at the #5 relay position for 83-84.. well I don't have a #5 relay position. I looked all around the area of the fuse box and there is no relay or place to put it.I've started the motor and it runs beautifully after it gets going but I have to put my foot into the gas to match the wide open air from that valve just to get it going. Then it idles at about 2000-2500rpm. If I unplug the valve I can get the revs back down to 1000 but only after adjusting the idle screw way up… otherwise it bogs down.
FYI. Someone before me removed the factory installed A/C and I believe that the car used to have a dual IACV unit like this but now just the white one remains and is causing the issues:
Has anyone else ever run into these kinds of problems?
Thanks,
Ian
