Tappety top end
(In Topic #205575)
Just had my engine swapped to the TSR block but the mechanic had to use my original head because the donor engine had carbs on. It is now very tappety once the engine gets warm and I never had this problem before. Any idea guys?😎
mk1 silver campaign totally standard lowered on coilovers magic tree vanilla
Just had a full outer body restore
So it wasn't a little bit tappety before with the old lump.
I'm a little surprised because normally they are like that from cold until the oil gets up there.
This is a question that often comes up about the big block engines.
Just read your signature, I think you might want to change that now a bit!
Just kidding.
Just kidding.
Just kidding.
It took me 7 years to post a picture!!
Just kidding.
So we all wait with baited breath for the next one!
Tappety top end
Mine is the same tappety when cold but still taps occasionally was quite before I serviced it used engine flush
What type of tappets do you have, solid type or hydraulic?
Tappety top end
I don't actually now it's a 1.8 8v
Tappety top end
Tappety top end
That's exactly what I thought but my mate thought otherwise
If you are missing a cam shaft cap when you remove the rocker cover you have hydraulic tappets, if you have all the caps in place you have solid shims, with solid shims you can buy replacement ones but you need to measure the gap between the cam and the shim (guide in Haynes manual) they do need checking every few years.
Hydraulic tappets adjust them selves but do also wear out, you can clean them out but which can help or buy new ones.
I think it's about 1985 when VW changed over to hydraulic tappets?
My Scirocco with solid shims, notice all 5 caps in place you will be missing No 4 (left to right) if you hydraulic tappets.
Tappety top end
Ok bud I will have a look and get a Haynes manual to thanks for the guide appreciate it
Bucks_recovery said
If that is your car in the picture and your car is newer than 1987 (when VW fitted the body kit) and the original engine in it I guess you will hydraulic tappets, does the noise comes and goes.
What oil did you use and what oil filter?
Tappety top end
It's a 90 spec I used triple qx 5w30
Tappety top end
Normal service kit from euros
You should really be using 10W40 in these old engines and I would recommend using MANN or genuine VW oil filters.
Lots of places sell the oil filters as they are fitted to a lot of cars/models.
Crosland Euro car part oil filter not very good???
5W30 a bit thin really???
I guess you made the mistake of following the link on the Euro car parts page on the oil choice?
Don't believe what the Euro car part website tells you as it wrong on a lot of parts and info.
Oil, this is the stuff VW uses.
AVS Car Parts
Genuine VW oil filter
AVS Car Parts
Euro Mann filter - click on the right hand side to change brand as it keeps going to Crosland in my link!
http://www.eurocarparts.com/oil-filter
GSF Mann oil filter.
http://www.gsfcarparts.com/120vg0090
Euro oil, I use this for the last 6 years and found it OK.
http://www.eurocarparts.com/ecp/p/car-accessories/engine-oils-and-car-fluids/engineoils/10w40-engine-oil/?521776011&0&cc5_245
Same oil here but £5 cheaper!
http://www.carparts4less.co.uk/cp4l/p/accessories-engine-oil/engine-oils/engine-oil/10w40-engine-oil/?521776011&0&cc5_245
AVS Car Parts
AVS Car Parts
Tappety top end
Time for another mini service then hopefully it sorts the tap dance class out
New sump plug washer is a good idea if you did not replace it last time?
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1990/p/car-parts/engine-parts1/engine-parts/sump-pans-and-sump-plug/?333771291&1&47c8751ced189bff5450784e05f1acd1b6276fd2&000567
Or from here?
http://www.carparts4less.co.uk/cp4l/c/Volkswagen_Golf+Cabriolet_1.8_1989/p/car-parts/engine-parts/engine-parts1/sump-pans-and-sump-plug/?333771291&1&e0aec9b5e00b9123d2c401ac898f4c8c66477e05&000567
Hope it does help but Hydraulic tappets do wear out, you can take them apart and clean them which may also help, there is a few guides on youtube but when I cleaned mine last year I could not remove the ball and spring from the insides as mentioned in the videos as it's not possible on my tappets as they are sealed.
Mine do sometimes tap a little when cold but they go quite again after about a minute and if you rev to about 2000 rpm then drop back to idle to get the oil pressure up.
Or from here?
Quick update. Had a local technician look at my engine and he says it's getting oil and everything seems OK. So the only thing he could put it down to is the bottom end might be too powerful for the top end. In other words the head could do with a full refurb to bring it inline with the rest of the car. So if this is correct should i use the original TSR head and fit twin 40's or bike carbs, go back to the 32/36 that was fitted to the TSR head or is there another option like adjusting shims?? 😎
Life Member
Blimey, you remembered all that after you drove away from the garage - or did the mechanic type it for you??!!!
I'd stick with the original engine and overhaul that!!!
