MK1 GTI 1.8 Cylinder Head bye bye...
(In Topic #166528)
Hi Guys,
I have a very rare car in my country, and Mk1 GTI 1.8. Actually it was the only one imported to Chile, I'm in the process to restore it. The engine broke down, unfortunetly the cylinder head is out, the time stopped of the car killed it.
I cannot repair it unfortunetly, I have the option thou of installing an MK2 1.8 8V cylinder head. The water and oil conducts look the same, but anyone has used it here? What about the k-jetronic, it fits?
Thank you guys!
Max
Thank you guys!
Max
if its a GTI head then yes, if it was a later digifant injection engine however you'll need to swap kjet injector inserts into it and your old ones may not fit. if not you'll have to source the correct inserts to match the mk2 head, earlier mk2 gti kjet ones should work
the only other potential difference is some later kjet have a vac connection between injectors 3 and 4, just cap this off if you dont have the pipework for it, or cap the pipe if you have the pipe but no port!
Hallo , you can change the engine with electric tree and the digifant two box
Guys sorry for the late feedback it worked perfectly I only put the inserts for KJet and it all went ok!!!
