Emission to high with no more adjustment. Help needed.
(In Topic #124755)
The first test showed 8.82%
After a bottle of redX, a good fast run up the motorway
and adjusting the mixture screw down.
The re-test showed a reading of 4.93% and it needs to be 4.50% to pass.
The engine is a 8v Digifant fuel injection in a mk1 golf with a K&N cone filter fitted. Vacuum hose from throttle valve housing to air box blanked of.
I have one full turn left on the mixture adjustment screw. If that does not work
what else need replacing or fixing to get the CO level down. Noted that the engine runs with on obvious problems and the CO level should be lower than 1.5%
Anyone got any Ideas.
On the last test the CO was 4.93% and the HC was 273ppm.
The engine sounds OK, but timing looks like a good place to check next.
Thanks for the response.
http://www.no-rice.co.uk/community/showthread.php?t=11429
ignition timing isnt something you can guess at, and you must set it using the proper procedure you cant set it at idle with a timing gun. as for idle + co, you need to do that in a special way also, using a co meter. cant just mess about with the co screw like you can on the older cars
Emissions
Had a go at sort the emissions out at the week end.
Replaced the Temp sender, dip stick funnel, vacuum pipes and the cam cover rubber bung. Everything else has been clean with injection cleaner.
I also checked the timing which seemed OK. I've been out for a run in the car and it is running great. More power in third and forth gear. Just got to re-book it in for a mot and hope this has done the job. Hope to get the garage to fine tune the mixture/CO level.
I'll keep you's up dated.
K & N
I will definitely by getting a K&N cleaning kit, unless anybody Knows a cheep way of doing it.
As to the spark plugs they look OK but would like to replace them for good measure.
The engine has got Bosch super W7 DC at the present time with 0.8mm gap.
But the haynes manual spec's Bosch WR 7 LT+ (1.0mm gap) with a Green ignition coil sticker and Bosch WR 7 D+ (0.8mm gap) with a Grey ignition coil sticker. Problem is the coil has no sticker. Note : the engine is a MK2 digifant injection.
Hi have thought about trying the tripple probe plugs, but have read mixed review for use on older engines
Just reread it though - you say its Digifant - did you fit and wire up EVERYTHING as it was in the old car, including the lambda probe? Did the engine run fine in the donor car it came from? How many miles has the engine done? etc
trippe probe plugs on a digi are fine, they dont offer anything over singles in terms of performance though, the extra probes just give em longer life. the reason i buy em though is the single probes can be bashed out of spec easily, where the trippes cant
Passed
Great the car passed it's MOT yesterday with a CO level of 0.87% vol and HC at 159PPM.
So Thanks for all the help and advice from everyone.
But replaceing the dipstick guide tube (which was cracked) and cam cover breather bung (which allow unregulated air to enter the crankcase ventilation system) has made a big difference to the power of the engine and they are very cheap part to replace. This may not have directly affected the CO level but were worth doing. This Tuning Guide can be found in Golf+ Magazine - September 2006 By Steve 'The Brain' Cresswell.
rubjonny said
have a read of my digifant tuning guide:
Hi Pal could you resend me the link please its broken, I'm trying to get my C0 down as mine also failed at 9.99%
