Cold start splutter for about 20-30 seconds!
looking at my previous message… it shouldn't have been the Thermo switch which i said for about £20 - correction! Thermo Time Switch - £75+++!!!
anyway, got a Voltmeter & had a look at this - connected up to the TTS & it was getting Voltage through it so it's not that.. took off the Meter head cover & gave this a clean… a small amount of cr P in there, also around the head itself… cleaned around there with some Carb cleaner… the Plunger seemed ok, moving quite well…
started her up & there was little splutter.. it is better!
Took her for a good spin on the Motorway & she felt good, accelerating nicely… with the top down the MFA is reading about 29-30mpg, not sure how good or bad that is as i've got nothing to compare to…
Just feel it's just not quite right..
perhaps when i get time, i'll check a few other things out (quite awkward to get to some things - need the right tools)
Cheers, Dean.
Last edit: by Deandubya
I found the engine runs smoother and has more performance on super unleaded.
Look at your spark plugs if black and sooty to rich, if grey OK if white to weak.
the digifant coolant temp sensor is blue, i have seen someone try to run a kjet engien with digifant sensors and that didnt go well at all
unless you're looking at the 5th injector?
http://www.partsplaceinc.com/products/product-detail.aspx?keyword=VW+Rabbit+Thermo+Time+Switch043-906-163A&sku=3047
Picture of it would be good.
i was troubleshooting a kjet mk1 for a fair while before i noticed it had an early digifant mk2 temp sensor which is similar looking to the thermoswitch.
he then told me it had an engine swap from a mk2 golf which he hadn't mentioned before
post up yr pics and part numbers then we can see whats what
pull the 5th injector and pop it into a pot then crank the engine briefly stone cold, it should spray. put it back in and fire the engine to warm it a bit, then pull it out again to recheck and it shouldn't spray
bit of corrosion is ok I've seen far worse on workin units. but from your testing looks like its dead so go shopping
Tried to start the car without the TTS switch connected & it wouldn't fire just turned over… so attached & fired up straight away (still my starting issue) when she was ticking over, got the cold smoke, if you like but there was slight drips of water.. does that mean she's running rich or something? or is it because it's now colder??? I've just googled that question - seems ok… physics!!! combustion- i'll leave it there i think…
once you're happy with the condition of the engine and the timing get down the local garage and give them some back pocket tax free cash moneys to get the co reset and you should be sorted
Last edit: by rubjonny
