Cab and Tin Top Petrol Tanks
(In Topic #73586)
I am putting a 16v in my Cab until i decide what to do with it and obviously i am going to have to fit an injection tank of which i have plenty from Mk1 GTI's but will it fit?
I can only presume it could be different due to the strengthening put into the shell by Karmann.
Euro Car parts list them as seperate items between the Cab and the Tin Top which got me thinking.
Secondly, what is the actual difference between the Injection tanks and the Carb tanks?
Paul
1982 Mk1 GTI 16v Mars
1978 Mk1 GTI 1.6 Mars
1975 Mk1 LS
1996 Mk3 Cab VR6 Turbo Project
1998 6n Polo Black
1984 UR Quattro Red
1961 Lotus Elite Silver
Mk1 & 16v Golf's Breaking for spares
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
I remember reading the fuel filler pipes are different for Cabbys so perhaps the tank has a slightly different location of the inlet pipe?
:dontknow:
Euro Car Parts have confirmed that all the Cab tanks are the same, but the Tin Tops have two which i/we already know.
So, does that mean the Cabs have a different type of fuel pump?
i.e an internal pump?
Any help would be much apreciated! Does anyone have a working copy of ETKA they could look at?
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
171 201 075P which is for the Carb models;
171 201 075Q which is for K-Jet and Diesal models;
For an 82 Cab, they list the same parts as the numbers above.
So I then checked a 90 Cab, and the same numbers get listed as above.
So, lokos like the cab tanks are the same as the tin tops according to EKTA but the carb runs a different tank to K-Jet.
I would say its becasu ethe K-Jet is preesurised system, where as the carb is not pressurised, so the K-Jet and diesal tanks are stronger due to the pressurised system they run.
I'm stuck now, i guess i will just have to take the tank off my Cab and compare it to the Tin Top GTI tank.
I cant understand why Euro Car Parts say that all the Cabs use the same tank from '84 onwards regardless of it being Carb or Injection.
The only difference between the tanks is the outlet for the fuel pump by the looks of it.
The only pressure in the tank is vacuam pressure, not actual force fed pressure, when you release your petrol cap the noise you hear is air getting sucked in, not air coming out.
If you cut a coke bottle in half and submerge it in water then lift it up you will get a vacuam as the air is pulled into the bottle.
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
One more question, has anyone used plastic fuel lines from a Mk2 on their Mk1 when putting a 16v in?
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
I have a plastic return, though the tank to engine pipe is the usual Gti piece…
My Build Thread
When I replaced the GTI cab tank I was told by my 'really excellent' VAG parts guy that it was specifically for the cab, its bigger, and has an internal lift pump.
The Clipper looks te same, apart from no internal lift pump !
Tank part number was - VA155201075B - price ?138.31 +VAT !!
Does it have an external pump too? Or just the internal one?
Getting somewhere now
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
Joining the suck or blow debate, ops: I?m sure my GTI blows out when I remove the cap? I can?t imagine any GTI burning enough petrol to maintain a vacuum, esp on a warm day when the petrol is being sloshed around. The petrol will evaporate and create a positive pressure? If vented after about a day in mid August it would have all evaporated??? :dontknow:
I dont know, but anyway, the tanks aint under any serious pressure, the diff between the tin top GTI and the tin top carb tanks is the petrol outlet positions.
But i'm still at a loss with regards to the Cab tanks
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
Websnowbo said
So your GTI Cab has a lift pump?
Both, when the internal one packed up it was a nightmare to drive - worse tan a kangaroo, and no guts at all, only going gently on the flat or downhill !!!
Main pump replaced 3 years ago, but it's always been noisy, had it replaced when an 'expert' garage said it was kernackerd, fitted a new one, - 'scrapped' the old one, charged me a packet, and it did not make any difference to my original fault.
Not been to them since……..
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
You know it makes sense!
I have the carbs but by the time i have bought the manifold, Pump and Regulator etc it will be expensive.
I'm only fitting the 16v because i'm going to VW Mania in Belgium in it and it is a bit sluggish on Motorways.
I'm going to G60 or 20VT it to make it more fun in the future. I'm not really into modifying cars as such, but i just want it to be more economical and nicer to drive.
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
I meant economy in relation to performance
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
