83 GTI not starting - got fuel, spark etc
Just spoken to my cousin, that was the first thing that crossed his mind when it backfired through the inlet. But has ruled that out by turning the dizzy full 180 degrees opposite and still got the problem. (this may not be how it's done, but i'm no expert either :wink: )
It's bizarre how one second it was fine then 5 minutes later it's not. (The only thing i can think of is that i overfuelled it when trying to bump it and then more problems have come as a result :dontknow: )
My cousin has got another mechanic to give it a full checkover today and start a fresh…
I'll let you know.
Once again thanks for the help, really appreciate it!
P.s. dont know what you mean about the injectors but i think he tried them by cranking the car for a certain amount of time and seeing how much each injector squirted and the shape of the spray
Has it been retimed with the correct mark on the cam pulley?
Just a thought!
even amounts, doesn't mean the fuel pressure is correct.joey said
Conical spray from all injectors with the same amount coming from each…
Right, firstly, moral of the story - assumption is the mother of all… ha ha
Obviously as i said before we had a spark and fuel but it just wasn't igniting. The spark however must not of been strong enough.
The end result was my ignition coil, which was bought from a well known parts shop very recently (Don't know if i should name them)
Other things did need changing, such as: Poor power lead going to the starter motor, HT Leads (Also low quality from the same shop), rotor arm, spark plugs and obviously fuel pump relay as mentioned before… But the main problem was the new coil.
Good thing is, it is now starting better than ever! and the sun's out
Thanks for all your help!
