2.0 ABF bottom end and 16V KR head rebuild Pic heavy
I drove 300 miles and it started to cut out at junctions. I had this before and I just turned the idle screw out 1/4 turn and it cured it.
I'm really tempted to go ahead with the metering head mod or do I go for the mk3 EFI set up and something like a Emerald 3 stage ECU and bigger injectors. All in time tho… I am enjoying the car too much.
now if you put the work you have done to the to your engine you should be looking at very healthy gains
but as you said enjoy it for now what you have ia not to shabby!!
Saab 93 diesel daily
Fuelling.
I've been towing with the idea of converting my GTi to ABF management. As you know, Tom from TSR Performance said the metering head couldn't supply enough fuel to get maximum results….
What do you guys think, I know some of you have a experience with this sort of stuff.
Would ABF management, I better set of injectors that may flow more and poss something like a superchip be better than the metering head that has been set up but not producing what it should? Also, it is a swine to get it to idle correctly as I believe there is something wrong with the idle adjust screw/seal. Maybe ABF management will solve this as it has a different throttle body?
What do you guys make with a super chipped ABF management. I am told to expect maximum of 6bhp and 5 torques max?
abf management is what I would do though as its much easier to work on and get spares for. no timing or idle adjustments to fiddle with, all ecu controlled! a chip will gain you around 4-6 bhp/torques, I have one on my abf. the power difference isnt amazing but the curves are much smoother plus the afrs were improved (checked before/after by toyotec)
heres the graph, totally standard ABF engine with jetex 2.5" exhaust:
ABF management over k-jet.
Seems you have a cracking engine for a lot less money! What a waste I have. I suppose it would be worth a try converting it back to ABF management to see if I can get some more fuel delivered to the engine via the EFI.
I recon it will either be the same or more?
but yeah my abf is certainly a very healthy one made loads more power than a std mk3 golf abf on the same day
Abf
lots of info here:
The Mk1 Golf Owners Club
I couldn't cope with the bottom end so I swapped the k-jet for the EFI ABF kit, this made a major improvement! However, these 288 cams are begining to be a pain. It is a swine to drive as you need to keep the revs up otherwise you kangaroo all over the road.
It goes like an absolute b*st*rd when you get going with te cams. Even with the extra mega power I've thought about selling them as I can't cope with the lumpy idling as the car has slowly become more of a daily runner.
Is anyone interested?
What is a good alternative? I have some KR cams in the shed still?
if you wanna keep the lumpy ones and have a nice daily it'll be megasquirt time
I'm not sure what to do, I've spent £1000's on this car :-s
Don't the KR cams have a slightly bigger lift than the ABF or have I got mixed up and sold the wrong ones :-s
Broken.
It's a good job golfs are really light ;-)
I have a sneaky suspicion the ECU and wiring has got damp with this crazy rain were having or maye the crank sensor is faulty.
http://www.vwsonline.co.uk/car_parts_bristol/037-906-433a.html
megasquirt is fully mappable so you can sort out the lumpyness no problem. its just more expense at the end of the day though if you just want a reliable daily a std abf is all you need really they are pretty damn quick without needign a lot of expensive parts, especially in a mk1. im more than happy with my std mk2 abf i wouldnt bother changing anything
theres a lot of discussion around about abf and kr cams, iirc kr more lift and abf more duration or something. but the consensus seems to be abf cams are a little better. but as i say if you have some kr cams then fit em, they'll work fine. claw a bit of money back sellign off those lumpy ones
How about a Emerald ECU. I used to have one, it had te ability to switch between 3 different maps.
