2.0 ABF bottom end and 16V KR head rebuild Pic heavy
Engine
Engine
I'm a little worried about the oil pressure.
I think the idling issue is because nothing is set up now it has new high lift cams and had a major air leak before. It also could be something to do with this throttle switch?
I know the ignition timing is out as I can't set it because the line on the flywheel is all over the place with my strobe light.
Throttle body
I've had a good search around and I cant seem to find anywhere that sells the over run cut off valve. Any ideas other than the dealer?
I think once all these are fitted I can get the car set up properly.
Does anyone know roughly how many mpg a well set up mk1 ABF/KR will put out with my modifications. Just out of interest?
Handy to have
http://www.torquecars.com/tools/uk-mpg-calculator.php
0-60, 0-100, 1/4 Calculator (this is very accurate, I have entered specs from websites such as parkers and they come up the same so this suggest it will work your cars spec out pretty well)
http://www.torquestats.com/modified/index.php?pid=calculator&action=calculate_times&drive=FWD&bhp=190&weight=810&submit=Calculate
BHPPT Calculator
quarter mile time Calculator 1/4 mile from weight and bhp
oil pressure is about 6 bar which is ok when cold, goes off the scale on my 0-5bar gauge. when warm it should drop to about 1bar
Engine
Just out of interest is the ABF rotary arm the same as the KR? I've fitted the ABF to my KR dizzy as the KR arm got damaged.
It's a brand new oil pump so the oil pressure should be bang on! There is no leaks what so ever too so hopefully it will stay this way.
I need to buy another allen key for the metering head set up as I've lost mine. Any idea what size it is?
Cheers.
ebay
http://www.ebay.co.uk/itm/AUDI-A4-RS6-VW-PASSAT-1-8L-OVERRUN-CUT-OFF-VALVE-B771-/270873519383?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f1151e517
abf rotor arm is same as kr, and loads of others. just the dizzy & cap that is different
Well I had the golf on the drive way today ready to try and set it up and it is dipping and increasing the revs all the time. I recon it may have a faulty Idle Air Control Valve.
After that I noticed water dripping from the bottom of the car. Turns out the brand new radiator that I've just bought is leaking. I'm gutted as I fear they wont exchange it an they will blame me for it braking :-(
I also noticed the fan has been glued in place preiously so I need a new fan as it has broken.
The other thing that was annoying is that my cool looking strut brace won't fit with this engine haha. Not to worry :-(
The joys!
Oh one more thing. How far up should the clutch arm go up as I've had it rebuilt and it seems to have loads of travelto the top before it actually does anything. This means my clutch cable doesn't fit unless it is adjusted all just way up and it has a spacer in between the cable and box
for the gearbox questions:
Welcome to BrokeVW.com
Engine
I'm off to GSF first thing tomorrow to see if they will swap my radiator as it is damages and i am assured my throttle body will be here before 12 in the afternoon, then I can leave it running and record everything for you to see if everything is operating correctly.
Ps do the videos I'm uploading work for you all? I've never uploaded one before and I'm doing this all from my phone so it would be interesting to know if I'm doing it right.
CO level. 2% adjustment
CO level. 2% adjustment.
http://www.golfgtiforum.co.uk/index.php?topic=22031.msg176891#msg176891
I got my new throttle body today, it looks in good condition. The only thing that worried me was the sensor switch itself, should the throttle arm actually touch the little sensor or not or is it a magnet which needs a certain gap?
the top arm needs to hit the switch, if you look at it closely you'll see the bit that actually triggers the switch can (should!) move on its own. if its sticky remove the 13mm nut from the tiop and the arm, spring and 2 plastic washers will come off. clean it all up nice and lube, then refit. take care when you put it on that you dont trap the spring between the washers otherwise it'll stick again, its fiddly as hell but you'll get there.
if top linkage is free to move but it still doesnt hit the switch undo the 2 small screws and adjust the switch position
Engine
that it contacts the switch, I've fitted it now and it still won't tick over on idle. Next job I'll try and adjust the CO then I'll look at the idle air control valve even tho it does buzz with the ignition on.
Engine
Is there any way of testing it? Would it give a voltage out of one of the wires when pressed in?
If the switch works I'll have to some how test the idle air control valve?
Sorry guys just Desperate to get it finished before Xmas :-(
