1.8 gti 8v
(In Topic #182143)
gets warm quickly
Mine gets up to temp within 5-10 minutes from cold too. Just make sure the fan kicks in when needed and your coolant levels and mixture are ok and happy motoring.
1985 Cabriolet GL
Tidzasteve said
Hi
hi yes mine does in about 5 min or so from stone cold but yes fan kicks in at just over half way and when driving stays there heater gets red hot in same time aswell just wondred if this was normal cheers
mark1gls said
Once its warm just make sure the bottom radiator hose is hot as the thermostat opens the water flow to the bottom radiator hose then on into the radiator, the thermostat can stick shut.
will check cheers
