radiator fan failure
(In Topic #188895)
mechanic says can't rebuild the fan..
and need to replace with new one..
anyone know the part number or where i can find it?
1976 golf mk1 1600cc carby model (made in australia)
please help me..
you may have to change the shroud too actually, not sure if the earlier shroud was same bolt pattern…
but any easier way? i can't even get mk2's fan
cuz. i live in korea.. its unique..
apart from that look around for fans that are available, they all work the same its just a case of get it mounted and adapt the wiring to run it.
on the VW loom if its a 1 speed its simple, red/black is live, brown is earth. if its a 2 speed (unlikely at that age I recon) then red/white is slow speed, red/black is fast, brown is earth
your fan is long since deleted, it has been replaced with 165959455T which is a 2 speed unit and you'll need to change the plug on it as well. if you do decide to buy it from the dealer (are there any?) then they will also need to order the plug and wire seals, it tells you in the parts ordering system which ones you need. you'll either have to only wire up the fast speed, or get yourself a 3 pin thermoswitch from later vw and wire that into your radiator fan loom
